Symbology doesn't refresh with scale level in ArcGIS Pro
1277
11-22-2017 11:15 AM
deleted-user-7-RuT5DYun5_
      In one of my ArcGIS Pro project, many layers do not adapt their symbology to the zoom level. bug
As you can see here, points, polygons and labels are way bigger than what they should be (Scale here is 1:213,020).
For example, the point symbology is supposed to be a 6pt dot with a 0.75pt outline.
Does anyone have an idea on why this happens and how to fix it?
Thanks.
AdrianWelsh
MVP Honored Contributor
Laura,
Have you given it time to refresh? What kind of layers are these with the symbology issues? Do all layers have these same issues? Which version of ArcGIS Pro are you using?
Adrian,
I did let the map refresh. All layers on this map have this symbology issue. It doesn't seem to be the case on a different map I created in the same project.
I am using ArcGIS Pro 2.0.0
