Symbology different sizes in map view vs layout view
1161
07-11-2025 08:29 AM
SaraJL
Hello everyone!
I'm running into a little issue that I hope is just user error on my part (or I missing a setting somewhere) but I've been noticing that the symbol sizes in the map view are not carrying over to the layout view. I've tried adjusting it, adding-readding the layer, but I'm a little stuck.
Here is the map view - it's easiest to see the differences in the windmill, but if you look at the relative size of the parking symbols:
It's significantly smaller in the layout view - if you look at the relative size of the windmill in this version:
Any suggestions are welcome! I can try and make the symbols larger in the map view, but then they get comically large in the map version.....
Thank you!
SaraJL
Yes! I did - I just realized it was this actual article that I needed. The way I was searching it - it was just not returning the exact article I was looking for.
Thank you!
DanPatterson
MVP Esteemed Contributor
have you reviewed this?
Symbol units and size—ArcGIS Pro | Documentation
... sort of retired...
SaraJL
Thank you!
