Super simple arcpy script using AddMessage
1563
01-27-2025 09:21 AM
TaiDuong
Apologies for my ignorance (in my defense I'm not a real coder) But can anyone tell me why this very simple script doesn't print the filename when I run the script from the Toolbox. I get the string so my AddMessage is working but not the filename
import arcpy
from sys import argv
def Model(RSI_TileSets="RSI_TileSets", Output_Feature_Class="C:\\Users\\john.oliver\\Documents\\ArcGIS\\Projects\\MyProject21\\MyProject21.gdb\\RSI_TileSets_CopyFeatures"😞  # Model
    # To allow overwriting outputs change overwriteOutput option to True.
    arcpy.env.overwriteOutput = True
    # Process: Copy Features (Copy Features) (management)
    arcpy.management.CopyFeatures(in_features=RSI_TileSets.__str__().format(**locals(),**globals())if isinstance(RSI_TileSets, str) else RSI_TileSets, out_feature_class=Output_Feature_Class.__str__().format(**locals(),**globals())if isinstance(Output_Feature_Class, str) else Output_Feature_Class)
    inFile  = arcpy.GetParameterAsText(0)
    arcpy.AddMessage("{0} completed.".format(inFile))
if __name__ == '__main__':
    # Global Environment settings
    with arcpy.EnvManager(scratchWorkspace="C:\\Users\\john.oliver\\Documents\\ArcGIS\\Projects\\MyProject21\\MyProject21.gdb", workspace="C:\\Users\\john.oliver\\Documents\\ArcGIS\\Projects\\MyProject21\\MyProject21.gdb"😞
        Model(*argv[1:])
DavidPike
MVP Notable Contributor
How was this script generated?  Did you grab it from a model builder output?
I'd guess it's something to do with the getparameter values being out of scope of the function, or that it seems to have hardcoded values into your function - but I'm not too hot on the model builder output 'scripts'.
I'd either really simplify it into a script tool or just use the Parse Path and Add Message functions inside Model Builder.
DavidPike
TaiDuong
Yes it's the output from ModelBuilder. Edited.  I'll take a look at ModelBuilder AddMessage. Thanks for that.
