Summarize Raster Within
3532
02-04-2020 02:35 PM
ThilinaSurasinghe1
I am looking for a tool to calculate mean across multiple rasters. I am aware of cell statistics tool that can be used here. I am also aware that raster calculator can also be used here. But, in my research I came across time tool: "Summarize Raster Within: Summarize Raster Within—RasterAnalysis Tools | ArcGIS Desktop
However, I cannot locate this tool in my version of ArcGIS Pro 2.4.3. The tool I could find were for polygons (summarize within), not for rasters.
This tool was refereed to in this tread. Any guidance on use of this tool will be greatly appreciated.
DanPatterson_Retired
Cell statistics allows you to do it in batch mode, however, you can only vary the statistics type, not the input rasters.
This is how you would "batch" a tool in any event.  Using Zonal Statistics as an example.
If your rasters are all for the same area (ie stacked up over time) then you can use arcpy's RasterToNumPyArray to process statistics at a local level.
I have a number of blog posts on how to use arcpy and numpy to do things that aren't builtin to ArcGIS Pro or ArcMap
/blogs/dan_patterson/2018/02/06/cell-statistics-made-easy-raster-data-over-time
/blogs/dan_patterson/2018/08/19/focal-and-local-statistics-for-rasters-without-the-spatial-analyst
plus others...
and a bit dated
https://www.arcgis.com/home/item.html?id=564707aec4f144c083e57656dae98022
plus others...
and a bit dated
ThilinaSurasinghe1
@Dan Patterson. Thank you. Thank you for those links and screen shots. I believe this is the way to go for my purpose. I also Figured that
Summarize Raster Within is only available via a specific license.
