I'm trying to compute the percentage of a field using the sum of all the fields:
$feature.FullVaccin / Sum($feature.FullVaccin)
But every time I test, I get 1.... What am I doing wrong?
Sorry for the confusion... The FullVaccin is the fieldname on AGOL while Join_Count is for the original table in ArcPro..... and the table has not be joined with another table.
($feature.Calculation * 1000)/Join_Count
This works but did not give the accurate percentage
Whenever I use the (Sum($feature.Join_Count)) It returns the exact value for each row
Hmmm... odd. This code works in AGOL, and if I edit the Layer through a feature service in Pro (this is different test data, but the same code as I originally sent structure wise)
var myid = $feature.Work_Unit_No
var mysum = 0
var myfs = filter(featuresetbyname($datastore,"TestPoints",['TestInt'],false),'Work_Unit_No = @myid')
if(!IsEmpty(myfs)){
var mysum = Round(($feature.TestInt/Sum(myfs,'TestInt'))*100,2)
return mysum
The reason your original code returned 1 every time was because it divided any number it found by itself:
So a tweak to the original code would be to create a feature set (in my example below called myfs) and pass that into the Sum function. If I want the myfs feature set to return all the rows in the Layer's table I can just remove the filter from my original response.
var myid = $feature.COJ_FacilityID
var mysum = 0
var myfs = featuresetbyname($datastore,"BogusPumps",['Integer1'],false)
if(!IsEmpty(myfs)){
var mysum = ($feature.Integer1/Sum(myfs,'Integer1'))
return mysumIf this doesn't work, I'm afraid I'm missing something that is right in front of me, but I just can't put my finger on.
