Sum() returning Nan Value
7081
13
04-20-2022 09:14 AM
godofsix
I'm trying to compute the percentage of a field using the sum of all the fields:
$feature.FullVaccin / Sum($feature.FullVaccin)
But every time I test, I get 1.... What am I doing wrong?
KimberlyGarbade
Hmmm... odd.  This code works in AGOL, and if I edit the Layer through a feature service in Pro (this is different test data, but the same code as I originally sent structure wise)
var myid = $feature.Work_Unit_No
var mysum = 0
var myfs = filter(featuresetbyname($datastore,"TestPoints",['TestInt'],false),'Work_Unit_No = @myid')
if(!IsEmpty(myfs)){
  var mysum = Round(($feature.TestInt/Sum(myfs,'TestInt'))*100,2)
return mysum
The reason your original code returned 1 every time was because it divided any number it found by itself:
So a tweak to the original code would be to create a feature set (in my example below called myfs) and pass that into the Sum function.  If I want the myfs feature set to return all the rows in the Layer's table I can just remove the filter from my original response.
var myid = $feature.COJ_FacilityID
var mysum = 0
var myfs = featuresetbyname($datastore,"BogusPumps",['Integer1'],false)
if(!IsEmpty(myfs)){
  var mysum = ($feature.Integer1/Sum(myfs,'Integer1'))
return mysum
 If this doesn't work, I'm afraid I'm missing something that is right in front of me, but I just can't put my finger on.
KimberlyGarbade
Try something like this... I'm running this in field calculator and filtering on an ID, but edit at will.
var mysum = 0
var myfs = filter(featuresetbyname($datastore,"BogusPumps",['Integer1'],false),"COJ_FacilityID = @myid")
if(!IsEmpty(myfs)){
return mysum
I ran this on the field "Float1" against this data:
godofsix
Thanks so much. I tried it and I still get the same 1 as the output result
KimberlyGarbade
Hmmm... what data type is FullVaccin?  Also, are you using Field Calculator?  If so, what is the data type of the field you are calculating?
godofsix
Long
KimberlyGarbade
If you are calc'ing into a Long also, it might not like getting numbers to the right of a decimal.  Try calc'ing into Float or a Double.
Since percentage is going to be a decimal number by definition it only show 0 or 1 when you calc into an integer type.
if you multiple by 100 it will show an int.
godofsix
Did and still got 1
Though, my ultimate aim is to use it for custom label in a web map
KimberlyGarbade
Still getting 1?  That is odd... are their any nulls in your table that you have to account for or does every row contain a FulVaccin value?
godofsix
There are no nulls
Here is the table:
KimberlyGarbade
Is "FullVaccin" off the page to the left?
Is the table joined with another table?
If you run a calc on Percentage again, and this time just  do something simple like
($feature.Calculation * 1000)/Join_Count
(just using data I see in your table); it will return a useless number, but does that result also show 1 every time?
