Stuck in Quick-Start Tutorial for ArcGIS Pro 3.4
748
12-07-2024 10:05 AM
NKUCER
I am teaching myself arcGIS while I have an internship and access to the software. I am going through the ESRI Quick-Start Tutorial "create a project" for version 3.4. I am at the point where I am using the locator pane to search for San Gorgonio but when it in no suggestions pop up below. I closed the project, restarted my computer and still, no suggestions are popping up. Any advice would be huge as I am so new to this.
BarryNorthey
Not sure about your setup but you can try this.
BarryNorthey
Click the Options pull down and make sure that the ESRI World Geocoder is checked on.
NKUCER
Thank you so much for answering my question. Unfortunately, when I click that drop down - the XY provider is the only line. How do i go about getting ESRI World Geocoder added there?
BarryNorthey
NKUCER
This worked! Thank you so much for your help!
