string and numbers
2547
8
07-16-2018 07:17 PM
ArmandoFreites
In a field string I need put 2 other field but format number.
FOR EXAMPLE I NEED:   NORTH: 25812,25  EAST: 25857.26
I PUT in python:  " NORTH:" + !POINT_Y!+ "EST:"+ !POINT_X!   ,  but ins´t correct
my field es a string type
DanPatterson_Retired
" NORTH: {}  EST: {}".format(!POINT_Y!, !POINT_X!)
should do it
ArmandoFreites
Thankkssss.  very useful
Armando. please mark the answer correct if it worked so others know a solution was found.
ArmandoFreites
Hello Dan. i find this solution
Very good.
Yes that can still be done.  But the 'format' method removes the need to perform conversion to string and the concatenation with the +.
The utility of this method will become more apparent when you have to use python 3 in ArcGIS Pro (soon )
ArmandoFreites
Ok Ok i need write more about Format(). But thanks a lot, it´s very important your job.
/blogs/dan_patterson/2016/03/01/basic-fancy-formats
my blog is full of stuff
it will probably keep you busy for some time
ArmandoFreites
You don´t like make videos????. Are excellent to for this cases.
