I have about four layers I am trying to publish from ArcGIS Pro to ArcGIS Online and I keep receiving a "Staging failed" error with no other details:
I found this article:
I tried to run through the troubleshooting but none of these options worked.
Facts: I can publish regular data from a regular coordinate system.
I am using a custom coordinate system and converted CAD data into a file geodatabase.
I have never had an issue with publishing converted CAD data from a custom coordinate system.
I tried one layer at a time and it still would not publish.
Are there any other ideas on what I can try to publish this data to the web?
I've even tried overwriting an existing hosted feature layer and creating a new feature layer. I do not have time-enabled data (as far as I know). There is no custom symbology.
Thanks.
I just ran into this issue. In my case, I solved the issue by repairing the geometry of my polygon layer. Hope this can helps someone else.
I ran into this error as well.
