Splitting feature class by attributes into same gdb does not carry over domains
1577
02-05-2021 02:21 PM
KathleenHoenke
I have an fc that I want to split by attribute. This fc is connected to several domains. I read on this post here: https://community.esri.com/t5/arcgis-pro-questions/splitting-of-polygons-in-arcgis-pro-2-3-changes-m... that I need to change the domain split rule to duplicate in the geodatabase, and then run the split. I did this, but, the domains still do not carry over to the 50 datasets I've split from the master.
I could script out the domains for each new split fc in a loop, but there's quite a bit of them, and was hoping there was an easier fix. Any advice?
Thanks!
