Split Polygon feature layer by the Polyline featur layer
3711
10-27-2025 03:17 AM
Labels (2)
TerkaHolubcova
Hello,
I would like to ask for your help. I have a polygon layer representing building blocks and a polyline layer representing borders.
I’m trying to find a way to split the polygon layer using the polyline layer. I only found the Split Features tool in editing mode, but it doesn’t seem to work for the entire layer.
It doesn’t look like it should be that complicated, so I assume I might be missing something.
Thank you,
Terka
3 Solutions
CodyPatterson
MVP Regular Contributor
Hey @TerkaHolubcova
I think you may have luck using the Feature To Polygon tool, as it contains polygons for areas enclosed by input lines, so everything inside of those lines would split!
https://pro.arcgis.com/en/pro-app/3.4/tool-reference/data-management/feature-to-polygon.htm
Cody
Robert_LeClair
Esri Esteemed Contributor
Another workflow I found that worked in my testing environment:
1.  In the Modify Features pane, select the Split tool.
2.  Click the By Feature tab.
3.  For Input Features, first set your line layer as the only selectable layer in the Contents Pane.
4.  Select all your lines in the lines layer.
5.  Click the Target Features tab.
6.  In the Contents Pane, unselect the line layer and select the polygon layer as the only selectable layer.
7.  Select all your polygons.
8.  Click the Split button lower right of the Split tool.
9.  Unselect all selected features.
10.  Turn off the visibility of your line layer and voila!  All polygons split by lines.
Good luck!
TerkaHolubcova
Hello,
thank you so much @Robert_LeClair!
I’m sorry for the late reply. After several tests, and because the polygons may not be enclosed by lines—it could look like this (I have tons of boundary lines and I just need to split the polygons using these lines):
@CodyPatterson  so I converted the polygons to polylines, trimmed the cutting border lines to match the polygons area, and then used Feature to Polygon to get the desired output.
The disadvantage of this approach is that I lose the polygon attributes and need to rejoin them via Spatial Join.
The approach from @Robert_LeClair  works as well, but since I have about 4,500,000 polygons and several million lines, the selection process wasn’t very convenient and was sometimes slow.
Anyway, thank you so much for your help—it really guided me toward my workflow.
Thanks again!
Best,
Terka
CodyPatterson
Hey @TerkaHolubcova
Cody
TerkaHolubcova
Thank you @CodyPatterson , I will test it!
Robert_LeClair
Good luck!
TerkaHolubcova
Hello,
Thanks again!
Best,
Terka
