Split Failed
3118
01-20-2023 10:24 AM
VanessaSimps
Hello-
I am getting the following errors when I attempt to use the Split tool.VanessaSimps_0-1674238684075.png
I can however use other editing tools successfully w/o this error message. I also tested creating a new polygon, successfully- oddly enough, I can use split on the newly drawn polygon, just not on existing polygons.
I have attribute rules set up for this feature class. There are two relationship classes set up on this feature class. I am working in a GDB on a SQL database. Layer has GlobalID and editor tracking turned on, versioning is off.
I have looked at other threads regarding the split tool, however the suggestions in them aren't helpful.
Thank you in advance,
Vanessa
VanessaSimps
Created a copy and tested- I am able to do the splitting  successfully.  Not sure why we suddenly started to get the error mentioned above. If anyone has insight just incase it starts up again, much appreciated!
VanessaSimps
