Split does not work with streamlined polygon
2829
10-08-2021 04:04 PM
Manu
I used the Streaming tool to draw a large polygon. Now I wanted to remove some patches inside, however, when I finish a circle with the Split tool, the following Error appears:
Split failed. Geometry must intersect polylines and polygons in two or more places.
The message did not appear when I tried the same with polygons that I drew using the regular "draw Polygon" feature
DanPatterson
MVP Esteemed Contributor
DanPatterson
Manu
Thanks, simplifying the Polygon made it editable. The Error message is a bit misleading, though.
Elin
Thank you, this worked. I have been searching for a solution for a long time. This is it!
Elin
JayantaPoddar
Assuming you are working on a Geodatabase Feature Class, could you make a copy of the feature class and try again?
Close all ArcGIS Applications, and restart ArcGIS Pro, if required.
Think Location
