Split comma separated values to multiple rows
8763
23
03-15-2024 05:59 AM
Ed_
by MVP Regular Contributor
Based on the sample data below I am trying to split each comma separated value in `MUNICIPALI` column to a new as shown in desired output. However, I am getting an error that `Projects_City` cannot open, it does not exist, but then I thought line 6 and onwards will create it. How can I fix this issue? On a side note, the comma separated values are a lot more than the sample data. For, example, one of them rows have 18 or something comma separated values so, will line 10 work for that?
Code:
import arcpy
# Import the surtax projects geodatabase table subset
in_df = r"O:\MyProject.gdb\Projects_City"
out_df = r"O:\MyProject.gdb\Projects_City_Updated" # Doesn't exist, expect it to be created in line 6
fldlst = ["OBJECTID", "PRJID", "MUNICIPALI"]
with arcpy.da.InsertCursor(out_df, fldlst) as insertCursor:
    with arcpy.da.SearchCursor(in_df, fldlst) as searchCursor:
        for row in searchCursor:
            for attrbPart in row[3].split(","):
                insertCursor.insertRow(( row[0], row[1], row[2], attrbPart))
Error:
  File "o:\path\SplitCommas2Row.py", line 6, in <module>
RuntimeError: cannot open 'O:\MyProject.gdb\Projects_City_Updated'
Update
After creating the table, please see updated code below, I am getting the following error, how can I fix it?
Code:
import arcpy
# To allow overwriting outputs change overwriteOutput option to True.
arcpy.env.overwriteOutput = True
arcpy.management.CreateTable(
    out_path=r"O:\MyProject.gdb",
    out_name="Projects_City_Updated",
    template=in_df,
    config_keyword="",
    out_alias=""
fldlst = ["PRJTID", "MUNICIPALI", "ZIPCODE"]
Error:
  File "o:\SplitCommas2Row.py", line 22, in <module>
IndexError: tuple index out of range
Sample Data:
OBJECTIDPRJTIDMUNICIPALIZIPCODE
11A1
22A, B1,2
33A, B, C1,2,3
44A, B, C, D1,2,3,4
55A1
66C3
Desired output:
11A1
22A1
32B2
43A1
53B2
63C3
74A1
84B2
94C3
104D4
115A1
126C3
Question | Analyze | Visualize
Tags (1)
2 Solutions
MErikReedAugusta
Okay, so a few things:
  1. As a general rule, don't nest Cursors in each other.  The efficiency generally takes a nosedive.
    • I think with an InsertCursor it's less of an issue, but it's still a better practice to separate them.  If this had been an UpdateCursor, you would have run through the entire table once for every row on the table.  (Meaning for your sample of 6 records, it would've made 36 passes through the table)
    • I would first run that SearchCursor and write the necessary data to a dictionary or something similar, and then run the InsertCursor to do your operations.
  2. In line 22, you're assuming your tuple has 4 entries.  In line 23, you reference 3.  Your field list and your sample data indicate you only have 2 entries to work with in the tuple.
    • SearchCursor returns a tuple of the same length as your field list parameter, which lists the values in the same order as those fields they came from.
  3. In your sample data, you have items delimited by comma and space (", "), but in line 22, you assume they're delimited by comma only (",").  I'm assuming this is just a formatting thing in how you typed up the post here, but be careful of differences like that.  Line 27 of my code below assumes there are spaces after the commas.
import arcpy
    template=in_df,
    config_keyword="",
    out_alias=""
fldlst = ["PRJTID", "MUNICIPALI"]
munis = {}
with arcpy.da.SearchCursor(in_df, fldlst) as sc:
    for prj, muni in sc:
        # NOTE: This assumes the values in PRJTID are unique.  If any repeat
        #  then you'll need to check the munis dictionary to see if you've
        #  seen this particular prjtid before, and append your muni results
        #  to the existing record, if you have one.
        munis[prj] = muni.split(', ')
with arcpy.da.InsertCursor(out_df, fldlst) as ic:
    for prj in munis:
        for muni in munis[prj]:
            ic.insertRow((prj, muni))
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
JoshuaBixby
MVP Esteemed Contributor
@Ed_, the updated code was close to working, you just need to use Python zip() function and change 2 lines:
import arcpy
    template=in_df,
    config_keyword="",
    out_alias=""
            for z in zip(*(map(str.strip, str.split(i, ",")) for i in row[1:])):
                insertCursor.insertRow(row[0:1] + z)
BobBooth1
Try creating the table first and see if it works.
Ed_
@BobBooth1 thank you for the quick response, after creating the table, I am getting a tuple error now, please see the updated post, thank you.
BobBooth1
I think you want "row[2]" here:
MErikReedAugusta
import arcpy
    template=in_df,
    config_keyword="",
    out_alias=""
munis = {}
    for prj in munis:
M Reed
Ed_
Worked like charm, thank you so much 😊
Ed_
@MErikReedAugusta can you please look at the modified sample data. It seems like I would also have to split the `ZIPCODE` column as well. How can I split both `MUNICIPALI` and `ZIPCODE` at the same time? Thank you
MErikReedAugusta
That depends on how those two fields should interact & combine.
Your sample data seems to be missing some potential combinations for PRJ 2, for example:
PRJMUNZIP
2A, B1, 2
I would expect the following:
PRJMUNZIP
2A1
2B1
2A2
2B2
(Your sample data is missing the second & fourth rows.)
munis = {}
# Search Cursor here; Fields [PRJTID, MUNICPALI, ZIPCODE]:
for prj, mun, zip in cursor:
    munvals = mun.split(', ')
    zipvals = zip.split(', ')
    joinvals = []
    for munval in munvals:
        for zipval in zipvals:
            joinval = f'{munval}|{zipval}'
            joinvals.append(joinval)
            del joinval
    munis[prj] = joinvals
    del joinvals, munvals, zipvals
Alternately,
I notice your sample data also has the same number of items for MUN & ZIP, though.  While it's not going to always be true in the real world, if your sample data guarantees a 1:1 match of municipality to ZIP, then you could do the merging that way, before you run the split.  If that's the case, you can replace the for loops at Line 9-13 with the snippet below.
Note: Because this assumes a 1:1 match, if you have 5 values in one column and 4 in the other, it'll just ignore that 5th value entirely.
index = 0
while index < len(munvals) and index < len(zipvals):
    joinval = f'{munvals[index]}|{zipvals[index]}'
    del joinval
M Reed
Ed_
@MErikReedAugusta  Thank you so much 😊 For the new snippet I am getting warning message that `cursor` is not defined. Do I need to define `cursor` earlier in the code?
Ed_
@MErikReedAugusta so I tried adding the cursor using the `with` statement and now I am getting the following error. Also, I don't if indented the `while` loop correctly or not.
NameError: name 'munvals' is not defined
Code:
import arcpy
    template=in_df,
    config_keyword="",
    out_alias=""
munis = {}
with arcpy.da.SearchCursor(in_df, fldlst) as cursor:
        munvals = mun.split(',')
        zipvals = zip.split(',')
        joinvals = []
    index = 0
        del joinval
