Spatial Join
1127
06-09-2022 02:53 PM
by Anonymous User
Not applicable
Is there a bug regarding the spatial join in ArcPRO?  We tried to join a table of addresses with a table of zip codes. Below Zip 5 should have zip codes, instead it has zeros just like the ZIP5 column. Has anyone had this happen before? I tried it in Enterprise and it worked using the two same data sets. Very strange. Thank you for any input. Annette
DanPatterson
Do you mean an attribute join? ( using common fields between 2 tables)  Spatial joins use the geometry between two files.
... sort of retired...
by Anonymous User
Not applicable
No, spatial join was used.  We have points and then the polygon is the zip code shape file.
DanPatterson
did you try the files in a file geodatabase rather than shapefiles?
The only issue I can find about "missing" is related to symbology, but since shapefiles don't support nulls (they become 0) it is hard to tell
Solved: Missing Polygons after Spatial Join - Esri Community
So try gdb featureclasses rather than shapefiles would be my first suggestion
