Spatial Join - join features to only one target
3697
11-29-2022 02:01 AM
Labels (3)
faoiltiama
I would like to make a spatial join and use every join feature only once.
Current Input
  • Layer1 = Lines of road segments --> Target Features
  • Layer2 = Point data of accidents --> Join Features
  • Join Operation -->Join one to one
  • Keep all target features --> check
  • Match Option --> within a distance (25 Meters because the points are not perfectly accurate)
Wish
Spatial join should match every accident to one and only one road. Output should have a Join count with the number of accidents that happened on each road segment. Each accident should therefore be counted on the closest road segment.
Problem
The only thing that doesn't work until now is, that the accidents can be assigned to multiple road segments this way. How can I prevent this?
DanPatterson
Are you using
Add Spatial Join (Data Management)—ArcGIS Pro | Documentation
which supports one-to-one
or
Spatial Join (Analysis)—ArcGIS Pro | Documentation
which supports one-to-many
... sort of retired...
faoiltiama
I'm using the latter, Spatial Join (Analysis)
JamesPoeschel
You can create a script tool for this.
You can rename the variable names if you like, in my case I was joining crashes to roads.
Here are the parameters:
And here is the execution code:
import arcpy
import os
# Define inputs and outputs
crash_points = arcpy.GetParameterAsText(0)  # Input crash points
road_lines = arcpy.GetParameterAsText(1)    # Input road lines
output_feature_class = arcpy.GetParameterAsText(2)  # Output feature class
search_radius = arcpy.GetParameterAsText(3)  # Search radius (e.g., "500 Meters")
near_table = os.path.join("in_memory", "near_table")  # Temporary Near Table
try:
    # Step 1: Generate Near Table
    arcpy.AddMessage("Generating Near Table...")
    arcpy.GenerateNearTable_analysis(
        in_features=crash_points,
        near_features=road_lines,
        out_table=near_table,
        search_radius=search_radius,
        location="NO_LOCATION",
        angle="NO_ANGLE",
        closest="CLOSEST"  # Only find the single closest feature
    # Step 2: Summarize crashes per road
    arcpy.AddMessage("Summarizing crashes per road...")
    summary_table = os.path.join("in_memory", "summary_table")
    arcpy.Statistics_analysis(
        in_table=near_table,
        out_table=summary_table,
        statistics_fields=[["IN_FID", "COUNT"]],
        case_field="NEAR_FID"
    # Step 3: Add crash counts (Join_Count) to roads
    arcpy.AddMessage("Joining crash counts to roads...")
    arcpy.MakeFeatureLayer_management(road_lines, "road_lines_lyr")
    arcpy.AddJoin_management(
        in_layer_or_view="road_lines_lyr",
        in_field="OBJECTID",
        join_table=summary_table,
        join_field="NEAR_FID"
    # Export joined features with crash counts
    arcpy.CopyFeatures_management("road_lines_lyr", output_feature_class)
    arcpy.AddMessage(f"Spatial join completed. Output saved to {output_feature_class}")
except Exception as e:
    arcpy.AddError(f"An error occurred: {e}")
    raise
 In my case, I only needed the join count per target feature. You may need to edit it if you need more information.
