deleting files from catalog doesn't delete them from contents pane
1733
11-24-2024 08:15 AM
Michele
My agency just "upgraded" to 3.3.1 and I have been having nothing but issues with this version.  Today I had some feature classes in my contents.  When I deleted them from the catalog, they remained in my contents pane, whereas in previous versions they would disappear as expected since I deleted them.  Am I missing something or is this a bug?  I checked the 3.4 release note fixes and this doesn't seem to be mentioned in there.
Debert
My understanding is that, from using older versions of Pro, datasets referenced in the Catalog pane do not get simultaneously removed from the Contents. If you delete the source dataset, you will get an error message notifying you in the contents pane. Again, needs to be removed, individually, from both.
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
BarryNorthey
I am using v3.4.0.
A feature class and layer are not the same thing. Conceptually, a feature class added to a Map becomes a Map layer. The feature class retains its Properties but a layer adds its own properties usually related to how the data source is presented in a Map such as labeling, symbology, etc. The same feature class can be added to a Map or many Maps in the current or other Projects and customized as a layer for each.
Reading through discussions from earlier versions, people were surprised and dismayed to find that deleting a feature class also deleted associated layers as you noted (at least from the current Map?). All layer formatting disappeared with the missing layer. This was also deemed to be problematic when a layer’s data source had been moved and they didn’t set the layer’s new data source before deleting the old. There are of course ways to deal with this before deleting a feature class.
In my tests, a layer is retained in the Contents pane of all Maps in the open Project after the data source is deleted as you discovered. The red exclamation mark denoting a missing data source did not appear in the current session. The attribute table of course can’t be opened and so on. The red exclamation mark appears when the Project is reopened.  In any case this seems to be intended to give people a chance to reset the layer’s data source thereby retaining the layer file Properties or to manually Remove it from the Map if no longer needed.
Note also the Geoprocessing option as set here.
Michele
Thanks for the thoughtful response Barry. As you said there are ways to deal with moving a dataset before deleting it.  It would be nice if the exclamation point showed up after moving/deleting it from catalog without having to restart the project. Some of my project have many layers and if I delete several fc’s at once now I have to do the same in the contents pane. At least there is a setting to turn this feature on and off.
