Spatial Join - Contain AND Boundary_Touches?
2693
10-13-2020 10:09 PM
hm_stella
Hello folks,
I got a question in using Spatial Join.
I made grids (polygons) which will make the sectors for the other layer of polygons.
I want to count the number of all polygons in each of grids, which may be inside the grid and stay cross the borders.
For example, I want the colored polygon at the left-upper corner to be included in the grid since a portion of the polygon is inside the grid.
So, I used spatial join with the matching option "Contain" but it doesn't count that part of the polygon. I think that option only joins if the polygon is inside the grid only.
I don't care about the overlapping.
Anyone knows the method to include all the polygons in the grid?
Thank you Geographers!
DanPatterson
MVP Esteemed Contributor
I would go through the graphic examples in
Select By Location graphic examples—ArcGIS Pro | Documentation
you can fine-tune your methodology
... sort of retired...
DanPatterson
hm_stella
Hello Dan,
I tried Intersect which perfectly matches what I needed.
Thanks a lot!
