Slow Editing in ArcMap 10.6
36355
68
02-06-2018 03:09 PM
KeithBurdette1
Anyone else having issues with editing in ArcMap 10.6?  Currently, my shop uses ArcMap 10.5.1 and I imported our existing template into 10.6.  Scrolling around works at a comparable speed but once I start and edit session, everything slows down.  Snapping is slow.  Mouse clicks response are slow.  Everything is slow.
In 10.5.1, we use the Attribute Assistant and Water Utility Network add-ins.  I've tried both the 3.1.2017 and 1.17.2018 versions of these tools and both are slow.
I tried a couple different methods to rebuild the templates and editing was still slow.
I've tried the steps on this blog post and nothing helped.
https://community.esri.com/groups/technical-support/blog/2012/06/07/troubleshooting-slow-performance...
I've cleaned the map cache and set the geoprocessing results management to keep for less than a day.
I've started a ticket with ESRI but was curious to see how many other people were experiencing this problem too.
Tags (3)
KeithBurdette1
SQL Server 2016
MichaelVolz
Esteemed Contributor
There was a patch needed for SQL Server performance with SDE 10.5.1, so maybe a patch will be needed from ESRI for 10.6 as well
KeithBurdette1
Yeah - we had an issue with mxds and sde datapaths in 10.5.1 that was solved by a patch.  Hopefully there is a similar fix for this issue.
CésarPires
When i am editing in the default version everything works fine, but editing in child versions all gets slow.
CésarPires
I tried to create a geodatabase in PostgreSQl 9.6 and the problem still persists, i think this is a problem of the upgrade of the geodatabase to 10.6.
MichaelVolz
Has anyone seen this slowness with editing when working against an Oracle SDE database?
AbeCoughlin1
Yes we have.
Windows 10. SDE 10.6. Desktop 10.6. Oracle 12.
deleted-user--MMnVrog9xw_
I had this problem as well. I went back to 10.5.1 because it was so bad. Editing in both file geodatabases and SDE was super slow and caused my arcmap to crash multiple time.
Were you able to get it working better?
KeithBurdette1
I have not been able to get it working better.  I too have gone back to editing in 10.5.1.
Too bad, 10.6 fixed a bug we were having but slowness is unbearable, I guess we will have to wait until 10.6.1
What did support say when you contacted them about it?
