Slope calculation with high raster resolution
1934
11-23-2024 12:15 AM
Fiona
I have a DTM with resolution in 0.25m. I use it to calculate the slope, but results seems like elevation curves, Anyone know the reason? Resample to 1m and change the symbology didn't help.
Bests,
Fiona
Fiona
I think I might be know where are the problem, the first one is after "Mosiac to new raster", the second is the original tif file. Probably the parameter in function I used were wrong.
DanPatterson
MVP Esteemed Contributor
Did you try slope in the new
Surface Parameters (Spatial Analyst)—ArcGIS Pro | Documentation
there are more options on how the surface parameters are calculated
How Surface Parameters works—ArcGIS Pro | Documentation
... sort of retired...
Fiona
Thank you for the suggestions, I have tried Surface Parameters, and også changed the naborhood distands to 1m/0.75m. The DTM is originally coming fra mosiac tiff, do you think it is the reason? Mosiac to new raster have been used her.
DanPatterson
a screen grab of the issue you are experiencing might be helpful to provide further comment
Fiona
Value from 90-0 degree.
Fiona
