Hyperlink not working ArcGIS Pro 3.2
5357
7
12-18-2023 10:22 AM
Yeaton
Hello All,
ArcGIS Pro 3.2
My database was built in ArcMap over many years.  I have a feature class with a text field "Addressfile". This, unsurprisingly, is a point file feature class that has supplementary info hyperlinked to the feature, such as photos, and asbuilts. The hyperlinks are activated by the "thunderbolt icon" in ArcMap. The destination for the links in Arcmap are folders in a shared drive particular to each address with pathways in the UNC syntax. The destinations are copy-pasted and scripted from my network drive in Windows File Explorer. The link is active and opens all data for the entire feature class when using ArcMap.
I have started to migrate to ArcGIS 3.2. None of these links works in ArcGIS Pro, and I haven't found a similar feature to the hyperlink thunderbolt as is available in ArcMap. Is it possible to link to a folder on a shared network drive in Arcgis Pro, or do all hyperlinks need a file extension, i.e. .pdf, .jpeg?
Thanks very much for any suggestions
Jordan_Brasher
Esri Alum
Hi @Yeaton, thank you for your post. I believe the behavior you are seeing is related to a known software defect:
BUG-000162956: The hyperlink link at the folder level does not work in ArcGIS Pro 3.2.
This bug applies to Pro version 3.2, so it might be worth testing demoting Pro to 3.1 to see if the behavior persists (it shouldn't). If it does persist in 3.1, I'd encourage you to open a tech support ticket.
I hope this helps!
Yeaton
Hi Jordan,
Just now checking in on my old post! I will take up your recommendation.  Thank you very much for your response.
Best,
Aaron
JerriBrown
Is it possible this will be fixed before a new version comes out?
GeoPolar
Same problem.
StephanieTaylor22
My org also has this problem.
BSBlagojevic
Unfortunately YES! Same problem!
jungao
the joy of beta testing for Arcgis Pro never ends.
