Slice Multipatch tool
1238
07-30-2024 10:13 AM
Jim_Riedmann
I’m using ArcGIS Pro 3.3.1.  I’m trying to use the Slice Multipatch tool.  Every time I run it, half of the multipatch is deleted.  Whether I set it to Solid or Hollow, the result it the same.  I used the “Is Closed 3D” tool to make sure it’s an enclosed multipatch.  There doesn’t seem to be any setting that says, “Don’t delete half the multipatch.”  Am I missing some obscure detail somewhere?
Jim_Riedmann
I found a workaround by replacing the offending multipatch.  That was less work than I thought it would be.  I was trying "Slice Multipatch" so I could avoid rebuilding a new one, but the problems with the slice tool took far more time.  I'm still curious why the slice tool is behaving as it is.
Jim_Riedmann
