skyline error
2547
8
06-29-2021 11:50 PM
JanjiraSukwai
I regularly use a skyline analysis tool, but in recent 4-5 days I get error messages "ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds".
Before that, I have successfully used the tool more effectively and smoothly. Now it is not stable. Any suggestions for this problem?
JayantaPoddar
First thing to do, log a case with Esri Technical Support.
Could you share a screenshot of the messages (Error, Input/output path, other tool parameters)?
Think Location
JanjiraSukwai
JayantaPoddar
Did you start receiving the error after an upgrade (e.g. Upgrade to ArcGIS Pro 2.8.1)?
Looks like the data is stored on a network drive. Do you receive the error if the Output Feature Class is saved in a local drive (e.g. C:\ArcGIS\Projects\...)?
Are there other users accessing/editing the same geodatabase objects (Feature Class/ Feature Dataset, etc.)? FAQ: Can multiple users edit a file geodatabase at the same time?
Think Location
JanjiraSukwai
Yes, it starts errors more often since the upgrade. Sometimes the tool seems to work but most of the time I get errors.
Anyway, no one can access or edit my data and I am the only user. I really have no idea why.
JayantaPoddar
One question still remains. Do you receive the error if you save the data in a local drive (Do Not use UNC path)?
One more way to check is to downgrade your ArcGIS Pro (Uninstall current version/ Install older version from My Esri). But you should get this done under the supervision of Esri Technical Support.
Think Location
JanjiraSukwai
Yes, I still receive the error when saving the data in the local drive.
I will try to downgrade it. Thank you for the advice.
JanjiraSukwai
This is my regular input parameter. I have no idea why errors occurred. Please help.
LenkaJanošíková
Hello, I have the same problem (having the latest version 3.0.3, input CRS checked). Is the issue fixed? Thank you for your reply.
