Sharing Layout Problems
440
07-21-2025 09:14 AM
EthanTapper
I'm having some problems sharing a layout to a georeferenced PDF. I've been using the same template project for a year -- no issues. This morning I went to create a simple new map and export the layout and:
#1: Exporting the layout now takes 5 minutes instead of 30 seconds;
#2: When layers are exported, the exported map has pulled back the top-most layer to reveal the one beneath in this strange grid (photo attached).
I have never had issues with either of these things, and have changed absolutely NOTHING about what I'm doing versus how I've been making maps and exporting map layouts on ArcGIS Pro for a year. I have tried creating new layers, new projects -- tons of different things, and I can't make this problem go away. Screenshot 2025-07-21 120818.png
Help?!
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
Ethan - I see you have an active class with Esri Support Services.  Were they able to answer your question about this item?
