Sharing joined and related attribute table from ArcGIS pro to portal failed!
3556
5
03-22-2019 01:18 AM
AyokunleAdebisi
I am trying to share a my attribute data which is as a result of joining and related tables to portal but it failed. when I checked online it requested me to remove join and relate before i can share. However I need these attributes. Please what should i do.
Tags (1)
by Anonymous User
Not applicable
Hi Adebisi,
Can you provide some additional information regarding the issue you're seeing?
  1. Provide the error message that you are receiving
  2. Is this being published from ArcMap or Pro (versions)
  3. Is Portal federated with Server--what are the versions?
  4. Any additional information
Thanks!
Best,
Luba
AyokunleAdebisi
ArcGIS pro 2.1.0.
I don't know if it is federated because I am using my school ArcGIS pro license.
by Anonymous User
Not applicable
Hi Adebisi,
You are receiving this error message because publishing web feature layers with in-memory joined/relate is not supported. This means that if there is a join or relate that was created in the map it will not allow you to publish.
If it is a join I have included the solution from our documentation:00226: In-memory joins and relates are not supported—ArcGIS Pro | ArcGIS Desktop
AyokunleAdebisi
Hello, thanks for your reply...can you please what could be the solution.
AyokunleAdebisi
Hello Luba,
Please I think if my reply is sufficient enough.
