Quick Import IFC to fGDB with Data Interoperability does not work anymore with ArcGIS Pro 2.3
1864
03-25-2019 04:18 AM
AlessandroValra
I've always used the Data Interoperability Quick Import to convert IFC into fGDB feature classeses without problems.
I used to follow the settings described in a Esri post and visible at this link: https://www.esri.com/arcgis-blog/wp-content/uploads/2016/09/QUICK-IMPORT.png?rmedium=bulk-arcgis-fil... .
After upgrading to 2.3 however the Quick Import stopped working as it did, throwing a generic error.
In the logs (comerrors-log-20190325.log), I see something like:
20190325-095325: HRESULT fail in file FMEArcToolboxUtil.cpp at line 552
20190325-095325: HRESULT fail in file FMEArcToolboxUtil.cpp at line 588
I really need help to understand how to solve this issue as it is blocking my BIM-GIS workflow.
I attach an IFC which used to work with the previous versions with the aforementioned settings (Rete.ifc).
I tried to restore the Data Interoperability installation but that did not sove the problem.
I noticed that in the IFC Parameters there's a new set of parameters that previously was missing (highlighted in yelow), maybe this could be of help...
AlessandroValra
Turns out it was the new antivirus. Disablding it made the tool work again.
AlessandroValra
