share a tpkx / Tile package as web layer - ERROR: Failed to publish web layer
1476
06-02-2022 07:22 AM
MR14
I want to share a .tpkx file (16 Levels of Detail, 12,4 GB) of an ESRI Basemap with the "share as web layer" - Tool. I get the following Errors:
- ERROR 001360: Failed to get basic item metadata for service definition upload.
- ERROR 001362: Failed to extract manifest from uploaded service definition. Failed to execute (PublishServiceDefinition).
- Server Response: Error Code 403, subcode:2 User does not have permissions to access ... Access to this resource is forbidden, regardless of authorization.
-  Publishing tool execution failed
-  Failed ErrorMessage: Failed to publish web layer
Has anyone else expierenced this and knows a solution?
Robert_LeClair
Esri Esteemed Contributor
Are you using ArcGIS Enterprise to publish to the portal or ArcGIS Online?  If ArcGIS Enterprise, what release are you using?
MR14
Hello Robert,
I'm using ArcGIS Enterprise 10.9.1 to publish to a portal.
