Set temperature model (raster) to logarithmic scale
277
08-28-2025 01:17 AM
GIS_User_1996
Hi everyone,
I have a temperature model as a raster from 40°C to 160°C, which I want to normalize between 1 and 10. However from 40°C to 100°C it should be a linear scale and from 100°C to 160°C it should be a logarithmic scale.
Does anyone know a tool or method in ArcGIS Pro to calculate the case above?
Thanks a lot in advance!
DanPatterson
Con should enable this since it is just a conditional evaluation
Conditional evaluation with Con—ArcGIS Pro | Documentation
Con (Spatial Analyst)—ArcGIS Pro | Documentation
OutRas = Con(InRas <= 100, InRas, Log10(InRas))
base 10 log as an example
Log10 (Spatial Analyst)—ArcGIS Pro | Documentation
to normalize it in the < 100 range
OutRas = Con(InRas <= 100, InRas/100, Log10(InRas))
... sort of retired...
DanPatterson
RTPL_AU
Honored Contributor
@DanPatterson  Have you considered retiring a bit less and writing a book, or even just dropping all your posts into a GitHub rep?   🙂
