Set Default Coordinate System for Dynamic Text
799
06-10-2024 02:21 AM
CaoimheMoy
Hi all!
I'm hoping someone might be able to suggest a solution here.
When using dynamic text boxes for upper right and lower left coordinates, there's a lot of editing needed to make it look how I need it to look, including; deleting extra text from the box, changing the colour of the text, and most annoyingly, changing the code every time to show the coordinates in meters instead of degrees.
Is there a way that I can do all of these edits once and then save this as a default? Currently it's quicker to just use a normal text box, go back and forth and change the coordinates manually each time, but I would ideally like to automate this.
Any tips would be appreciated!
