Selecting polygons that intersect with 5 or less points
1089
05-16-2023 04:16 PM
RoryEscobedo
Hi!
This might be a simple problem, but I keep getting stuck.
So, I have many polygons (about 500). A mass amount of points overlaps these polygons. I want to select only the polygons that intersect with less than 5 points (0 to 5). Once I select these polygons I want to remove them from the map.
 I have read up on the SQL (https://community.esri.com/t5/arcgis-pro-questions/perform-a-sql-count-in-calculate-field/td-p/11339...) just an example, and seem to keep running into problems. I feel like this should be an easy solution, but I keep getting stuck!
jcarlson
You could probably do it with Arcade, too.
var pts = FeatureSetByName($map, 'points layer name')
var xs_pts = Intersects($feature, pts)
return Count(xs_pts)
The resulting count would give you the ability to select by attribute and delete.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
