Selectbylocation and CopyFeatures via Arcpy
4210
6
06-21-2021 01:04 PM
ZoeChen
Hello everyone, I am having trouble when trying to automate the process of select-by-location and copy-features in python. My codes looks like below: The logic seems to be right but once it runs, it runs forever which definitely exceeds the time I ran in Arcpro. Any ideas would be appreciated, thank you!
import arcpy
from arcpy import env
env.workspace = "D:/Backup/shapefile/NE_validation"
outworkspace = "D:/Backup/shapefile/NE_validation"
NEEEfishnet = "D:/Backup/shapefile/NE_validation/NE_validation.gdb/NEEE_NewEngland_fishnet"
shplist = arcpy.ListFeatureClasses("*Point*")
for shp in shplist:
        # select by location
        arcpy.management.SelectLayerByLocation(NEEEfishnet, "INTERSECT", shp, None, "NEW_SELECTION", "NOT_INVERT")
        # export selected features (use copy features tool)
        outfeature = outworkspace + "/" + NEEEfishnet[52:75] + shp[37:40] + ".shp"
        arcpy.management.CopyFeatures(NEEEfishnet, outfeature, '', None, None, None)
        # clear selection
        arcpy.SelectLayerByAttribute_management(NEEEfishnet, "CLEAR_SELECTION")
Update: I change the code to adopt two more functions: make feature layer and save layer to file. The code runs but it does not produce shapefile that is openable. The error message says below. I am going to stop updating, and maybe someone someday will find a solution to this problem...
JoshuaBixby
MVP Esteemed Contributor
Selections don't apply to data sets, they apply to layers or views.  Although you can now pass a data set directly to a Select Layer tool (personally, I disagreed with this change when Esri made it a couple years back), the selection isn't being made directly on the data set.  Instead, when a data set is passed directly to a Select Layer tool, a layer or view is created behind the scenes and the selection is placed on it.  With your code, you are not retrieving the auto-generated layer.
I still personally think it is best practice to create a layer first and then pass it to Select Layer tools.
DanPatterson
does it produce output though?
... sort of retired...
ZoeChen
Thanks, Dan, it does not produce any output.
DavidPike
MVP Notable Contributor
definitely add some print statements to try and track what's going on, I would also separate the directories that your outputs are going into as it's asking for issues.
ZoeChen
Thanks, David. 👍
JoshuaBixby
ZoeChen
Wow, thanks for this answer Joshua! It really cleared my puzzles 👏
