Select polygons that have points inside
5754
02-10-2022 01:41 AM
SoknaLy
I have a polygon layer and a point layer (two separate layers). When overlapping, some points fall into some polygons. I want to select only the polygons that have points inside. How can i do that? Any ways, tools or SQL queries can help?
Thanks!
JohannesLindner
MVP Alum
The tool you're looking for is Select Layer By Location.
You can open it from the Geoprocessing Pane (Data Management -> Layers and Table Views) or from the Map Ribbon:
Parameters:
Input features: polygons
Selecting features: points
Relationship: Intersect
If nothing is found, try using a small Search Distance.
Have a great day!
Johannes
JohannesLindner
MVP Alum
Parameters:
Have a great day!
Johannes
SoknaLy
Hooray! Problem solved!
Thanks Johannes. You saved my day!
