Select line on line in same file
1248
04-20-2021 06:04 PM
DanSeidensticker
I have a street centerline shape file where segments for bi-directional roadways are drawn as two stacked lines. The top segment for one direction of travel, the bottom segment for the opposite direction of travel.
I need to separate these stacked lines into two different shape files.  Anyone know how to select just the top set of lines so I can export them to a different file. I can just use switch selection to get the second set of lines then.
Unfortunately none of the table attributes represent the top versus bottom segment, or direction of travel.  The geometry of the top and bottom segments are the same.
I looked at commands such as Find Identical, but that still selects both the top and bottom at the same time.
Looking for a solution in ArcGIS Desktop 10.6.1 Advanced or ArcGIS Pro 2.6.2
Tags (3)
DanPatterson
see my answer Re: Select lines on lines in same file - Esri Community
... sort of retired...
