Select by lasso duplication error
528
07-30-2024 01:31 AM
ChenaySimms1
Good day all
I keep running into an annoying issue when using the Select by lasso function in an Edit vertices session. When I move vertices using this tool the entire selected feature gets duplicated so that I end up with the original feature, as well as a new duplicate feature showing the edited vertices. I then have to go back and delete the duplicate, only for this to happen the next time I move multiple vertices. If I move each vertice individually then the feature doesn't get copied and only the vertice gets moved. I didn't have this issue in the previous versions of ArcGIS Pro but it has been happening consistently since moving to ArcGIS Pro 3.3.1.
Is this user error or a bug? Any suggestions on how to prevent this from happening?
