Select and delete features based on a condition of another polygon layer
2660
10-22-2023 10:01 PM
BrigitteColin
Hi all,
I have the following challenge.
- 1 building footprints  (800.00 records)
- 1 state-wide layer (50 records showing 50 subareas)
I want to select/delete all building footprints that fall within one subareas polygon in the state-wide layer.  It sounds so easy but I can not find the right tool.
The SQL code would look like this.
Select all polygons that are within the subarea xyz of layer state-wide (the second polygon layer)
Any ideas please?
Thank you!
BrigitteColin
To all - I found the solution myself !  🙂
I did a def query to filter on this one specific record in the def query and then I used the select tool. This combination works.
JohannesBierer
BrigitteColin
Hi Johannes,
The select tool is a good start, but I can not set the condition of using only one record. I can set the relationship between the two layers, meaning intersect, or within or contains etc. This mean the whole dataset is considered and not just one record.
What I am after is that only one record will be used (of 50 in total).  For example,  select all building footprints of layer 1 and then delete all those building footprints based on an bigger polygon overlay of a single record of  layer 2.  -> Delete all building footprint in a selected polygon that contains all the single building footprints of layer 2.
The Select tool allows me to set a distance only. Should I use this?
Any ideas please?
BrigitteColin
