SEDF creating additional fields; Shape_Length and Shape_Area in gdb fc
1415
02-14-2023 03:41 PM
TylerT
I work a lot with Spatially Enabled DataFrames (SEDFs).  I have noticed that when using the df.spatial.to_featureclass(*some.gdb) method, two additional fields are created in the in the output gdb feature class (Shape_Length and Shape_Area (if applicable)) without request.
Has anybody else noticed this behavior and have any ideas how to suppress this?
Thank you,
Tyler
ArcGIS Pro 3.0.3
DanPatterson
MVP Esteemed Contributor
some fields in a file gdb can't be deleted or their creation suppressed because they are required and managed by the gdb.
Field—ArcGIS Pro | Documentation
import arcpy
z0 = r"C:\Arc_projects\Test_29\Test_29.gdb\clp"
[f"{i.name}, {i.required}" for i in arcpy.ListFields(z0)]
['OBJECTID, True', 'Shape, True', 'Shape_Length, True', 'Shape_Area, True']
You can hide them
ADDENDUM
added ... or their creation suppressed ...
to clarify
... sort of retired...
TylerT
I wasn't asking to delete them, rather to not create them without explicitly doing so.  I have plenty of feature classes without those fields.  Anybody else?
One reason I'm looking to avoid their creation is because Shape_Length and Shape_Area are reserved names for web layers.
Tyler
