Script Tool issue
3259
10
09-26-2024 08:26 PM
MarkHammond4
I have a script tool which is supposed to apply a definition query to all layers in a feature service in the map and then remove all empty feature layers from the Contents pane.  The tool can successfully apply the definition query but fails to remove the empty layers.  I put the code to remove the empty layers in a separate script tool and it works! Any idea why that code won't work in the same script as the definition query code?
def script_tool(param0, param1,param2):
    """Script code goes below"""
    aprx = arcpy.mp.ArcGISProject("CURRENT")
    m = aprx.activeMap
    for lyr in m.listLayers():
        if lyr.supports("DEFINITIONQUERY"):
            #If the Clear Queries option is checked:
            if param2:
                lyr.definitionQuery = ""
            else:
            #Apply definition query to all layers in the map
                lyr.definitionQuery = param1
                #Remove empty layers
                arcpy.conversion.ExportFeatures(lyr, "temp")
                results = arcpy.GetCount_management("temp")
                count = results.getOutput(0)
                if count == '0':
                    m.removeLayer(lyr)
    aprx.save()
    return
if __name__ == "__main__":
    param0 = arcpy.GetParameterAsText(0)
    param1 = arcpy.GetParameterAsText(1)
    param2 = arcpy.GetParameterAsText(2)
MarkHammond4
I don't get any error or warning messages.  Yes I've amended line 18 to match yours and even tried removing the Clear Queries option and the if/else statement for it but it makes no difference.  Another person tested the tool and got the same results I get.  What version of ArcPro do you have?
