Sampling raster returns no values
2920
11
04-22-2021 04:49 PM
DougTurk
I am attempting to sample data from a vegetation raster layer using ArcGIS Pro v2.7.3, but the resulting sample file contains no data. I've tried using the Extract Values to Points tool and the Sample tool, and neither one seems to work (the jobs complete, but no sample data is ever collected). The raster layer I am using is part of a geodatabase that I obtained from CalFire. The raster layer includes an attribute table with 16 fields. I created a random series of sample points within a specific area covered by the vegetation raster layer. I've attached screenshots of the sample points over the raster layer, the vegetation layer attribute table, and images of the two empty sample tables. Any advice on why my approach isn't returning any data would be very much appreciated.
Thanks!
DanPatterson
So what was the solution? It appears yours was marked correct? confused
... sort of retired...
DougTurk
Apologies, I'm still a newbie at this. Your solution worked.
