Risk Management
2135
6
07-12-2021 05:47 PM
CanJM
Hi, I have flood plain or stormwater , location of all the asset within an area. I am trying to identify which assets are at risk.
DanPatterson
MVP Esteemed Contributor
If the pinkish area is the flood plain, go with my suggestions
select by location for the points and polygons
and intersect for the lines
... sort of retired...
DanPatterson
Select features by location—ArcGIS Pro | Documentation
Is a possibility, also one of the Overlay tools, like Intersect or Pairwise Intersect
An overview of the Overlay toolset—ArcGIS Pro | Documentation
would be a good start, depending what and how you intend to do the identification
CanJM
DanPatterson
What do you intend to do with a DEM?
If it doesn't add to the analysis, don't just start adding things.  Your work will lose focus 😉
CanJM
floodplain + municipal water management + our asset locations = identifying the equipment that is most at risk (That's my goal).
DanPatterson
CanJM
I will give this one a try and let you know. Thank You
