Revit model in ArcGis Pro
7937
14
09-10-2018 03:38 AM
vamsiboppana
Hi Friends,
I Have a 3D model building Layout Revit file ".rvt" and i need to publish the same into  ArcGis portal through ArcGis Pro. Is it possible in ArcGis pro?. if yes please give some steps.
And can we work out scaling, Geo-referencing, through ArcGis pro.
Thanks
vamsi Boppana
Luiz_AmadeuCoutinho
vamsiboppana
thank you for your reply... can i get any video help. how to work 3d revit file like scaling, Move, Geo-referencing, and publishing into portal through Arcgis Pro 2.2 version.
Is it possible without using "Data Interoperability" option in ArcMap.
Thanks in Advance.
vamsi.B
XanderBakker
Esri Esteemed Contributor
ZachJaffe
vamsi boppana
I am currently having the same problems. Were you able to resolve it?
Thanks!
Zach
DanPatterson_Retired
vamsiboppana
Thanks in Advance.
vamsi.B
KoryKramer
Esri Community Moderator
I checked with our Scene Layers team and it sounds like you can convert to a multipatch feature class then create the scene layer (currently). Direct share of revit to scene layer is planned for 2.3.  I hope this helps.
Cheers
vamsiboppana
Thanks for your reply.
We converted Multipatches feature class conversion in .gdb. but after loading the data from .gdb(revit converted data) we are unable to get the color same as revit file.
How get back the same colors(which we shown as revit).
Thanks in Advance,
vamsi.B
