When will Revit 2023 files be supported in ArcGIS Pro? I am using ArcGIS Pro 3.01.
Thanks!
This will be supported in the ArcGIS Pro 3.1 release which is to be released in Q1 2023.
thanks,
Andrew
thanks,
Andrew
any idea when in Q1? this can help to inform projects when collaboration with BIM and GIS is ongoing.
Current target is end of February but that is always subject to change as we get closer.
thanks,
Andrew
Thanks Andrew - it sure would be nice if Autodesk shared information with their partners before they shipped a new version.
@Stefan_Thorn After battling this every year we finally bit the bullet and make nightly IFC exports of all our Revit data that our GIS users need rather than trying to use IFC for those months where Revit has updated and native Revit files the rest of the year.
Hi @mrmark
Thanks for share your work process. I tested it too with the project that is using Revit 2023 and have suggested it to the design leader to have this same approach.
But export to IFC is not always possible as we experienced in an other project. (see image) When working with federated models which have linked models that are mirrored and/or rotated, these models Revit cannot export with the IFC export nor there is a solution from Autodesk.
Not even to mention the impossible manually workload to georeferencing linked models where the survey and project base point are 0,0,0. A way to derive the actual coordinates from those linked models and translate this into a wld3 file would be a helpful for collaboration in GIS.
Does ArcGIS Pro 3.1.5 supports Revit 2024?
