Retain Export Location in Project File
1507
11-30-2021 08:43 AM
RobertBorchert
Honored Contributor
Is there a setting I can select in ArcGIS Pro to save the export location to the same location based on the project layout.
I have numerous Pro Projects that I use for a variety of projects that export pdf maps.
However, Pro seems to default to that last export location used, no matter what the project.
thanks
Tags (1)
ABishop
Hello Robert,
I would say that if you are exporting the PDFs manually, you are stuck setting the PDF export location manually.  But, if you create a python script or model using the "exportToPDF" method, it will allow you to set a default export location.
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/mapseries-class.htm
Amanda Bishop, GISP
RobertBorchert
Honored Contributor
No we don't set up python scripts for basic things like exporting maps individually.
this particular map series has 803 polygons in the series and we only export 1 at a time every so often and we need to update the ticket number
ABishop
Since its only every so often, shouldn't be a problem setting the export location manually?
So sorry I don't know how you could make this the same location each time for every user.
Amanda Bishop, GISP
