Resize the name of label
1773
6
05-10-2020 05:21 AM
UmitGunes
I would like to resize the name of some counties just like attached figure 2.
But I couldn't achieve it. I could just do figure 1.
Figure 2 generates the font size according to the area of the country.
Thank you
Figure1
Figure2
Tags (3)
DavidPike
MVP Notable Contributor
Sure thing:
It's hidden away in the placement properties (how about calling it size and placement esri?)
DavidPike
Is this in ArcMap or Pro? there are several options to adjust the font size proportionally. Figure 2 is likely aided by proportional sized text, but almost certainly not solely by it, I am sure those are annotations.
UmitGunes
Thank you very much.
I use Pro. How can I do that.
Thank you
DavidPike
Sure thing:
UmitGunes
Thank you
I tried but itis not what I expected. Please review the below figure.
Thank you
DavidPike
Your label placement should be set to 'Land Parcel' or similar for this to take effect. This will of-course stop small island nations showing-up. A quick fix for this would be to duplicate the layer and use definition queries to filter the display, and adjust label properties accordingly. You could alternatively control the amount of over-run in the over-run properties.
UmitGunes
Dear David,
I understand it now and it worked.
Thank you
