Reproject Utility Network Dataset
1626
08-14-2023 06:39 PM
DeepikaJain01
Dear Community
I am working on creating telecommunications Utility Network Dataset, for that I have downloaded the telecommunications UN Model from ArcGIS Solutions and I am trying to fit my data into it. I am running into issues in reprojecting the Communications_UtilityNetwork.geodatabase which has the actual UN Model built with the Business rules. I have inserted my data into AssetPackage.gdb. Please help!
MattSchwartz7
Esri Alum
Hi @DeepikaJain01 !
If working with the solution, there should be a Task in the UN Solution that walks you through re-projecting the data! This should be the Change Asset Package Spatial Reference Tool. I opened the Water Distribution solution and this was the task I was referring to if it's helpful!
https://doc.arcgis.com/en/arcgis-solutions/latest/tool-reference/utility-network-package/change-asse...
MattSchwartz7
Esri Alum
Hi @DeepikaJain01 !
