After the Add Join Function i have Object Id and Id replicetes in the attribute table. I tried to use the Add Field Tool but it didnt work so thats the only way i managed to extend the table.
Does anyone know how to delete those replicates? By now its grayed out.
Thanks for the help!
Solved! Go to Solution.
If you post a screenshot of the tool parameters and of the error message, I and other users might find out why.
So you converted a raster to polygons, ran Zonal Statistics on the raster and now want those statistics in the polygons?
You used Add Join. This tool virtually adds all fields from the join table to the target table, based on the specified relationship. The fields aren't really in the table (in the database). ArcGIS just displays them inside the current project. As they aren't really there, you can't delete them.
Multiple options:
Thanks Johannes, very kind!
Yes, all true except i used Zonal Stat to Table and then added the values to the polygons.
I tried the Join Field Tool aswell but gives me errors all the time. Any clue why?
KG
