RepairGeometry example 2 stand-alone script does not work
1963
12-02-2024 07:55 AM
KatClifton
Attempted to use the RepairGeometry example 2 stand-alone script provided in Esri documentation to back up erroneous geometries and then repair them. Script fails on the CopyFeatures line, meaning that erroneous geometries are not able to be copied to another feature class before being corrected.
I did update the path to the table that was generated by the Check Geometry tool.
Repair Geometry (Data Management)—ArcGIS Pro | Documentation
Here is the sample script directly from the Esri documentation.
# Description:
#   Goes through the table generated by the Check Geometry tool and does
#   the following
#   1) backs-up all features which will be 'fixed' to a "_bad_geom" feature class
#   2) runs repairGeometry on all feature classes listed in the table
import arcpy
import os
# Table that was produced by Check Geometry tool
table = r"c:\temp\data.gdb\cg_sample1"
# Create local variables
fcs = []
# Loop through the table and get the list of fcs
for row in arcpy.da.SearchCursor(table, ("CLASS")):
    # Get the class (feature class) from the cursor
    if not row[0] in fcs:
        fcs.append(row[0])
# Now loop through the fcs list, backup the bad geometries into fc + "_bad_geom"
# then repair the fc
print("> Processing {0} feature classes".format(len(fcs)))
for fc in fcs:
    print("Processing " + fc)
    lyr = 'temporary_layer'
    if arcpy.Exists(lyr):
        arcpy.Delete_management(lyr)
    tv = "cg_table_view"
    if arcpy.Exists(tv):
        arcpy.Delete_management(tv)
    arcpy.MakeTableView_management(table, tv, ("\"CLASS\" = '%s'" % fc))
    arcpy.MakeFeatureLayer_management(fc, lyr)
    arcpy.AddJoin_management(lyr, arcpy.Describe(lyr).OIDFieldName, tv, "FEATURE_ID")
    arcpy.CopyFeatures_management(lyr, fc + "_bad_geom")
    arcpy.RemoveJoin_management(lyr, os.path.basename(table))
    arcpy.RepairGeometry_management(lyr)
The following error is returned:
ExecuteError: ERROR 160144: An expected Field was not found or could not be retrieved properly.
Failed to execute (CopyFeatures).
DanPatterson
MVP Esteemed Contributor
That is an example script.  Did you modify it's inputs to match your situation? (ie. featureclass name, field name)
... sort of retired...
KatClifton
Hi @DanPatterson , yes I modified the script to read the input in my environment.
In my original post I indicated that I did update the path to the table that was generated by the Check Geometry tool.
Thanks.
DanPatterson
and the field name for the searchcursor?  Was it also called "CLASS"
SearchCursor—ArcGIS Pro | Documentation
KatClifton
@DanPatterson - yes, the search cursor was called CLASS in my table as well.
DanPatterson
Well that leaves the .OIDFieldName
and the error message, which I assume you saw already
160144: An expected field was not found or could not be retrieved properly.—ArcGIS Pro | Documentati...
only suggests one course of action, so I would contact Tech Support if your layer does have an object id name
or try adding a check to the code to test whether there is an OIDFieldName using 'hasOID' from the table properties method
Table properties—ArcGIS Pro | Documentation
Tech Support may have other bug not listed below that return similar responses
Esri Support Search Results
