Repair Geometry Failed
9987
12
03-14-2025 06:50 PM
SydneyHeathcott
When I trying to use the Feature to Raster tool I get these horizontal streak lines, another post said that the Repair Geometry tool should help to fix this and when trying to run the Repair Geometry  tool I get this error message
999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
I tried pulling the feature into a blank project to run in case it was an issue with the project and the same thing happens. I then thought I'd try to go a round-about way by doing Feature to Polygon then Polygon to Raster, but Feature to Polygon failed with this error message
160196: Invalid Topology
SydneyHeathcott
unfortunately, the errors are with data i need. I've attached a screenshot of what the message looks like, i'm starting to think it might be a bug and not something i've done. I'm going to try to go back to the 3.3 version and see if that makes a difference bc i've exhausted everything i know to try
DanPatterson
MVP Esteemed Contributor
well short segments and self intersections as the error states,
If you could select a few of those and export/save those to a new empty geodatabase, maybe the trip to a new home will make them better, If not, I wouldn't waste any more time since nothing has helped apparently and Tech Support should be better equipped to deal with issues like this.
... sort of retired...
SydneyHeathcott
this is an update - I downgraded back to 3.3 and started my project over and it has fixed this issue.
