Remove XY pins
2219
01-07-2025 09:33 AM
Level_Seven
I have XY pins (the blue ones) currently added to my map, but I need to remove all of them. A solution provided by a community member back in 2014 does not work in ARC PRO. Can anyone provide steps to remove XY pins after they've been added. I asked previously but was mistakenly provided information to remove points. This is not a points, lines, polygon issue, I simply need to remove the XY pins ive added. Thank you.
** ESRI - I wish you provided real time online support, it becomes a depressing assault to one's confidence when simple solutions take hours to problem solve and delay work deadlines.
Level_Seven
Never mind - I figured it out. Not sure how to delete my post.
For anyone else with this issue:
1) Click on "selection" tab, in the contents pane (LEFT SIDE)
2) Right-click on "graphic" - there's a little check box
3)"remove" once the "graphic" is selected.
4)she gone! I added another a new pin once the others were deleted and replicated this process and it worked again. Hopefully this helps others.
Level_Seven
KristenHanratty
Thanks so much for providing an update. Your solution was the only one I found that helped me with the same issue!
LetaFranklin
Very glad you didn't delete your post! There was nothing intuitive about this. I share your frustration.
