Remove overlapping areas between two features
2459
05-04-2021 04:25 PM
snoe72
I have a polygon in a specific shape and I want to remove this area from a raster. Specifically, I have a polygon outlining prairie soil in Illinois, and I want to remove this area from the USA soils crop production raster. When I use the clip raster function, it clips out in a rectangle the area around the prairie polygon.
I need to either make the prairie values zero or remove them from the raster.
Please help!
DanPatterson
With the appropriate license...
Erase (Analysis)—ArcGIS Pro | Documentation
or this
Pairwise Erase (Analysis)—ArcGIS Pro | Documentation
There are other methods using Con and other tools if you want
... sort of retired...
JayantaPoddar
MVP Alum
You can use Extract by Polygon (Spatial Analyst) , choose extraction area as "OUTSIDE"
Think Location
