Remove items from list in python toolbox tool
2979
08-11-2022 10:40 AM
WadeWall
Hi all,
I am trying to create an ArcGIS Pro python tool that prepopulates a list with field names from an imported shapefile. I want to be able to delete field names from the list, but the tool I have created won't allow it. I am guessing that I need to add some type of update part to the script, but just not sure. In the tool, a red "X" appears next to each field name, but when clicked does not actually delete the field name. Any help would be appreciated. here is the tool as it currently exists:
class FieldNames(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "FieldNames"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        fc = arcpy.Parameter(
            displayName="fc",
            name="fc",
            datatype="GPFeatureLayer",
            parameterType="Required",
            direction="Input")
       names = arcpy.Parameter(
            displayName="field names",
            name="fields",
            datatype="GPString",
            direction="Input"
        names.parameterDependencies = [fc.name]
        names.multiValue = True
        params = [fc,names]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        # This comes from here https://gis.stackexchange.com/questions/330672/deriving-field-parameter-from-table-parameter-in-python-toolbox
        if parameters[0].altered:
            parameters[1].values = [field.name for field in arcpy.ListFields(parameters[0].valueAsText)]
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        # sat = parameters[0]
        fc = parameters[0].valueAsText
        fields = parameters[1].valueAsText
        return
JohannesLindner
Yeah, Python toolboxes have some weird quirks you have to work around.
Personally, I've never gotten Parameter.altered to work. I always do the check myself by comparing the current parameter value to the previous value stored in a variable. But it doesn't work with a variable of the Tool class. Something to do with the internal conversion into C code, I guess. My workaround for this:
Create an empty class in the toolbox file. Use this class to store variables from your tool classes:
# Toolbox.pyt
class ABC():
    """This class is used to store tool variable."""
    pass
    def __init__(self):
            displayName="fc",
            name="fc",
            direction="Input")
            name="fields",
            direction="Input"
        # set the variable. Doesn't work with self!
        ABC.fc = ""
        params = [fc,names]
        return params
        return True
        # instead of Parameter.altered, do the check yourself
        if ABC.fc != parameters[0].valueAsText:
            ABC.fc = parameters[0].valueAsText
            parameters[1].values = [field.name for field in arcpy.ListFields(ABC.fc)]
        return
        arcpy.AddMessage(f"fc: {fc}")
        arcpy.AddMessage(f"fields: {fields}")
class Toolbox(object):
    def __init__(self):
        self.label = "test"
        self.alias = "test"
        self.tools = [FieldNames]
Have a great day!
Johannes
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - Esri Community
will get rid of the sad faces and provide code line numbers
... sort of retired...
WadeWall
Thanks. I will follow the rules next time!
JohannesLindner
# Toolbox.pyt
class ABC():
    pass
    def __init__(self):
            displayName="fc",
            name="fc",
            direction="Input")
            name="fields",
            direction="Input"
        ABC.fc = ""
        params = [fc,names]
        return params
        return True
        return
    def __init__(self):
        self.label = "test"
        self.alias = "test"
Have a great day!
Johannes
WadeWall
I am not sure how you figured that out, but thanks a lot. I would have never arrived at this for a solution.
